I cant send any messages, I am again using WLM 8.5 and windows 7.
This started last night before i want to bed, before some messages couldnt be sent.
GrumpyCat says:
hi
The following message could not be delivered to all recipients:
hi
GrumpyCat says:
Hello
Hello
I can attest to this, as im not receiving them.
Check your firewall btw. disable it to test that its not interfering btw.
It has been off even though i thought i re enabled it.
Especially if it’s norton, alot of stuff can set off norton, especially programs like this
I dont use norton, I use avast, it started working again, but now its not working, its seems to be intermittent
Well it seems to happen the most during the night, I cant send any messages right now as far as I am aware.
They won’t send if the contact is offline btw.
Even if they are online it still wont work
Dunno then :/, probably just your network
Try reopen WLM you and your partner as well.
