Is it even possible?
How to have wlm 2012 and msn 7.5 both installed
Windows Live Messenger is not yet supported by Escargot so, for now, it’s not really a problem.
Anyway, I don’t think you can have both installed because the installers check for previous versions and remove them. The only way would be to use a “portable” version (one that doesn’t need to be installed) of MSN Messenger 7.5.
