How to get Digsby to connect to Butterfly Messenger?
#1
Yo, anyone? Has anyone ever used Digsby before or even heard of it? I’ve currently downloaded this program. Digsby runs on HTTP, whereas Butterfly Messenger runs on HTTPS. When I added a Windows Live account on my Digsby, it fails to log in.
I wonder if I can get my Digsby to connect to my Butterfly Messenger.
My Windows Live account in my Digsby uses " muser.messenger.hotmail.com " as an IM server. What IM server is my Butterfly Messenger using? Is it the same one Digsby uses? Is there a way to get my Digsby to connect to Butterfly Messenger by making it think I’m using a Windows Live Messenger?
So what do you think? If you have any ideas, tell me. I’m gonna need your feedback. Also, please ask Jonathan about this. Thanx. :slight_smile:
#2
In case you don’t know what Digsby is, check out the site. Click the following link below and you’ll see what I mean.
#3
windows live messenger 2012 and butterfly messenger uses msnp 21 which is using https its a encrypted.so if digbsy does not support msnp 21 /https i dont think there’s a way to work. you better ask jonathan via e-mail or on messenger if you have him on your contacts
#4
Alright, man. I will. :slight_smile:
#5
look here
#6
Thanx for the link. :slightly_smiling:
#7
works for msnp21???
