Greetings! Eric After Eric from Discord and IRC
Today I am going to tell you how to create Escargot fan site rip website.
Inspired by @Patrik_Heim
- Firstly we are going to open web.archive.org then type messenger.microsoft.com in the box , select a date that you want
- Press Ctrl+S and select “Save HTML Only”, the dialog looks like this
- Select a location to save and you will see the html file
- Open it with any text editor , I will use Visual Studio Code as example
- Open up the replace dialog of every text editor. On Visual Studio Code, it looks like this
- Replace Windows Live with Escargot
- Click “Replace All”
- Don’t forget to replace MSN and Messenger with Escargot , and replace the links with escargot.log1p.xyz
- (optional) Replace the text too
- Host your website on a host , I am going to use GitHub Pages as example
- Create a repo on GitHub named [whateveryouwant].github.io
- Turn on GitHub Pages in the settings
- Upload your file, then it’s done
- Enjoy
Hope you find this post useful
Did you know?
Two thirds of kids on MessengerGeek spent their life doing the same useless thing.
Please let the kids do something useful, like learning HTML, CSS and JavaScript.
#SaveTheKidsOnMessengerGeek
