How extract win xp icon with high quality and in format JPG or JPEG?
well, read the title
use PNG, it’s transparent.
just extract a icon from resource hacker (if you using XP) or customizergod (if you’re using XP on a vm and you mounted the VM’s hard drive to your PC), and convert said icon to png.
thanks
hey (sorry for bump) but i coverted files using paint and stills have a blank background look:
imagem and is a PNG
use iconsextract https://www.nirsoft.net/utils/iconsext.html save the one you want to as ico in the icons folder, choose your preferred available size of your icon https://redketchup.io/icon-converter then convert it to PNG https://convertico.com/ico-to-png/ and you have a nice transparent icon :stuck_out_tongue:
thanks
i only getting 256 color icons
when i convert
i cant convert to a 32 bit color
that’s the website fault, try using another one
Le big bump
