So I am trying to make a local server to test WLM '09, and I am currently stumped with instruction #4 (installing dependencies) and #5 (create settings_local.py). When I attempt #4, this happens:
And for #5, I do not know HOW to create the file. Any help would be appreciated!
Edit: And yes, I know, I probably sound like a fucking moron right now. lol
EDIT 2:
Actually, I think the screenshot points to the problem.
install -m pip install -r requirements.txt
It’s supposed to be:
python -m pip install -r requirements.txt
As for settings_local.py, just create a normal text file and add the settings in lol.
That just gives me an “unknown command” error
try python3
instead python
just install python with command sudo apt-get install python3
I’m on Windows 10, and I installed python 3.6 yesterday
