So on August 27th my laptop started to lose files and explorer would always refresh even after resetting.
The next day my gaming PC didn’t get infected.
Is this a virus or a UEFI corruption?
PC: Dell Latitude 7370
HDD: LITEON 256 GB NVME SSD
Boot Mode: UEFI
Windows 10: Version 2004
Do a virus scan, check the status of your SSD using some software.
I hope this is UEFI corruption, also racommend me some software.
Also Task Manager is disabled and explorer doesnt launch at all.
Ok, you have gotten a virus.
is there any way to remove? should i delete all of my partitions and reinstall?
Try using malwarebytes.
i told you i cant acsess the explorer
Try booting into safe mode.
nothing. it’s gone forever. im sad
rip dell 2019-2020
What error you get when booting to safe mode?
Reinstall windows.
You should install a TRUSTED app that can help you recover your account files
nothing has worked.
i gave up.
ill just stop with vms and other stuff.
will just stay with my pc, close this topic PLZ.
Well i installed windows 10 and windows 95 on vms and the WLM works peefectly so i do not need to delete nothing
So these things caused pc to not work?
it was a kms tool that hacked my laptop not my other pc’s so i wont turn it on
now please close this topic, i will NEVER install any cracks ever again.
