First off I can’t login with my martinike@protonmail.com e-mail, despite resetting my password.
And second of all when I click on the “Open your e-mail inbox” button, it crashes the entire program and logs me off:
Try reinstall, because I don’t see any problem in the 8.5 version
Or try install Messenger Plus Live or unnistall and downgrade and later install 8.5 again
My other accounts were working and I freshly installed 8.5. Should I downgrade?
If messaging isn’t broken, you should be fine.
This has nothing to do with my problem?
