can someone create a sound pack for me i need msn 2002 (7.5) sound .wav files can someone send it to me becouse i can t install it on my pc ![]()
oh, I use 2009
windows live messanger 2009
escargot dosn t support 2009 yet how you do that
Hes using '09 with a generic faulty server using Escargot’s source code
thanks man ![]()
its all all the MSN Messenger 7.5 sounds compressed in .zip format the sounds should go to this directory:
For 64 bit systems: C:\Program Files (x86)\MSN Messenger
For 32 bit systems: C:\Program Files\MSN Messenger
ye i know but i can’t install 7.5 becouse give me an error during installation
what OS are you using
windows 10
it worked for me… try using the “Compatibility” tab in the setup programs properties
ye i did but no luck:(
quote exactly what the error message is saying
i don’t remember exactly but i don’t care i will use 8.1 and change the sounds ![]()
