guys i’m getting 80048821 error on 8.5 on windows 10 now
it was working perfectly ,i installed wlm 2009 for tryng sxsri server i went back to escargot and now it’s not wworking help please
windows 10 20h
wlm 8.5
you cant use 2 cilents on 1 computer.
i suggest to delete wlm 2009 and delete all the hosts files from the host folder
and then try again. use zap messenger to delete the messenger references. > https://zapmessenger.en.softonic.com/
i did i unistalled with zap wlm 2009 and after i installed 8.5
ok i edited the host file and … yeah the problem was that for some reason was mapped to connect to myself :192.168.1.89
Wait,did you reveal your IP address?
Edit and remove YOUR IP address if it’s your real one
its a local IP, don’t scare yourself!
Phew
and again, there is no geolocalisation on his shown IP
That is a private ip so its not as bad as revealing your public one.
man it’s a private adress not the public one ![]()
Guys mine is: 21.126.7.152 (it was a joke!!)
mine is 12.345.6.789
yo mine is 69.420.32.666
mine 127.0.0.1:8080 (jk) dont set this as your proxy
