i tries use instructions to launch msn to my winxp machine but i can’t login with that error 80048821 and idk is possible to solve that
oh diddums,
Which version did you try to install? Did you run the registry patch after?
i fixed now but i can’t call in 7.5 version is strange
How did you fix it, just so people know if they find this thread.
i change long password to eight-digit password bcuz msn have that bug and only on that way you can log on to msn
Can’t be true, mine is only 6 chars.
more than likely you would have been putting the wrong password in.
well i have errors when im tryi log on but after 3 tries all ok
