oof
Try again.
Convert a jar to a apk. I have a jar of Windows live Messenger 8.5. I got it from Escargot MSN in smartphone. Go to the post then get the jar then convert it to a apk then patch it then give it to me.
can i have a link?
Oops! That page doesn’t exist or is private.
Oops! That page doesn’t exist or is private…
Then search Escargot MSN in Smartphone?
In smartphone? So I smash one to find it?
just do it
I think that version used the XMPP endpoint?
Install the English one.
The com.pica one the one in this file. TESTING PURPOSES.zip (2.2 MB)
Fuck it, I’m gonna drop this here.
This is from the Escargot GitLab, issue #72;
“…While looking at the .class files for any server handler code, I got across examining m.class, which I believe is the server handler, and it utilizes the XMPP frontend, which we haven’t implemented yet, instead of raw MSNP.”
This is probably the same.
