tengo el mismo problema, no me inicia sesión
Same problem here…
i have No errors in Escargot
you’re so lucky
I have the same problem.
now works good
server off again
UPDATE:now im online, you better check again if you have problems.
They’re servers problems.
I have also encountered a login problem last night. Server was timing out.
48hs+ … server off… or error persistent
try again now…im online.
no :c error persistent
I don’t know anything about this particular situation right now, but in my prior server development experience and what’s been said here, it could be that the server is low on memory, has held connections that aren’t timing out, something along those lines, in which case until it is resolved, just continuing to try repeatedly will probably let you in.
yes! :c
Well, i don’t have any problem with Escargot server
Attention, my solution is:
At the start, remove the 3 tildes, remember account, remember password, log in automatically. Say yes to the alert. Then re-enter the data and you can login.
