Error number
81000306 end Error 80072ee7
My Windows 10
[image]
[image]
Hi, I had a problem logging in
Windows Live Messenger 2008
When I log in, I get a number error : 81000306
81000306 means the server is congested, and the connection timed out, 80072ee7 means the client is unpatched
I have this error 81000306
i think it was a compatibility error and it prevents login
a solution that worked for me is to check the connection settings, if you have a proxy (only if you have), try why that was my problem and also check the TCP connection
