"Error establishing a database connection"
#1
http://escargotspaces.com/powerwindows/
my website won’t load and it pops up this error :sob:
escargot spaces = brick???
/s
aight but seriously the fuck is going on
#2
I did secure the DB file permissions yesterday since it was apparently downloadable before then.
I’ll temporarily restore the original permissions and see if that fixes the problem.
#3
#4
Well restoring the DB’s original permissions and accessing the blog doesn’t change anything.
Try making a new blog now.
#5
i dont know how to i havent used spaces in months :sob:
#6
Guess that means your blog was created long before I changed the DB permissions.
Maybe WordPress borked something up. :confused:
#7
no i just made a new acc idk why lmao
#8
Oh. :stuck_out_tongue:
#9
so yea how idk
#10
So I decided to create a dummy space on the admin account and I also get the same error.
I’ll try restoring the DB permissions once again and create yet another Space.
#11
So I created yet another dummy Space, this time with the (very risky) permissions set, and I’m getting the same error.
Maybe there’s something else wrong. :confused:
#12
filler e e e e e e e e e
#13
Checked out the error log.
There seems to be a lot of “Table doesn’t exist” errors.
And from checking phpMyAdmin, the tables WordPress complains about not finding don’t exist. O_O
Perhaps I’ll run a repair on the database and see what happens. :stuck_out_tongue:
#14
wat
#15
So I’m currently getting a deployment version of Escargot Spaces working, with the theme and all, to see if I can reproduce or figure out the problem the actual Spaces currently has.
#16
After setting up the deployment site, I created two test blogs on it, pre and post-BuddyPress installation, and both blogs were accessible. I then had the feeling that the database on the main site was screwed up, and from searching up the error, I can pretty much conclude so.
Guess it’s time to reinstall WordPress.
#17
Before I reinstall WordPress though, I’ll need to back up the existing users and functioning blogs that are already in the database. Unfortunately, phpMyAdmin wasn’t cooperating with me when I tried exporting the tables, so I’ve successfully set up MySQL Workbench to remotely connect to the Escargot Spaces database, and I’ll do the backup tomorrow. :slight_smile:
#18
k
#19
Finally got to fix the bug, but it seems that the UTF-8 characters got screwed up along with it.
#20
UTF-8?
Like Unicode?
Spell “Pig” backwards and then say “pretty colors” to win a free ipod nano 5th generation
