Thanks Gel, that worked to re-revive Messenger with the newest Reviver.
Seems the last Cumulative Update of Windows 10 (KB3093266) killed the functionality again to login into WLM. The old trick with Photo Gallery is also not working, the login screen is showing short time and then terminates itself.
Cheers
Tom
I have the same problem as Tom, hope it can be fixed.
Same problem here, tried re-reviving with 2.4.5.3 since re-reviving has worked in the past, but no go this time.
Having to use Skype for the time being, but I can’t stand all the white space on the sides.
have you report that on jonathan??? tried to uninstall that update?
Confirmed this breaks Messenger.
Uninstall it then hide it from updating again
Yup, did the same, uninstalled and hide it.
Solved also other problems which I had that shortcuts didn’t work correctly
Cheers
Tom
Cools, good to know it was not just me that was having the shortcut’s problem.
All good without that evil update.
Thanks guys, I think I’ve fixed this in the latest version if anyone dares unhide the update to try it out.
Thanks Jonathan!
Tried it and works fine.
Thanks. You did it AGAIN Jonathan. After downloading newest update, Messenger and WLM working again. Many thanks.
