WLM 2009 said “Calling USERNAME HERE” instead of “Messenger is not available right now” when trying to call
Yes it works for me i tested it its few days ago
You probably port forwarded, as well as who you were calling, so nothing has changed it seems, since i still get messenger is not available
Well I didn’t port forward anything, not even my friend
Well then i guess its UPnP (if that works) or something like that
well my router does have an option for MSN in its Application Layer Gateway settings but i cant enable it
no, it still has the same issues as before
Then I don’t know what is going on
Out of curiosity, which router type and model is it?
But any MSN ALG is going to be for versions prior to 4. After that, Messenger switched to UPnP and there was no use for an ALG, and it won’t do anything.
i cant find the exact model but i know its an Asus router
