Balazs's MSN Love! Program
#21
i said i stopped developing of msn love.
#22
ok
can i make a little site for it?
#23
ha nagyon akarod
#24
de windows live stílusban csináld ne azon a retros stíluson
#25
As I said, you might consider winks and emoticons first. :slight_smile:
#26
@Balazs_V tudom hogy nem windows live stílusban van de ha akarod tovább fejlesztheted
ha akarod elküldöm pm-ben (a kódot)
#27
What’s with the weird text effects on the near-readable HTML? :confused:
#28
i put it for some kind of censoring :stuck_out_tongue:
#29
Why would you want to censor source code that could also be viewed by looking at the public site’s source on your browser? It just doesn’t make sense.
#30
yeah its easy to view it like this ;-;
#31
ne folytasd mert nem ilyen weboldal lenne a cél. Olyan weboldal kéne ahol már neten le lehet tölteni a scripteket és egyszerű feltöltés gombbal fel tölthetem a scripteket. Weboldal PHP, jQuerry és PHP-en írodna.
MSN Love! official site
#32
ha akarod akkor max changelogba csinálhatod
#33
i will fix the msn 4.7 patcher and ill ad spotifinger
#34
add spotinger*
#35
Messenger Love! doesnt launch on Windows XP :stuck_out_tongue:
#36
What kind of error?
#37
Possibly an .Net error.
#38
MSN Love runs on .NET 4.0
Probably you did not installed it yet.
#40
Yes i know tha :slight_smile:
I have i installed it 2 weeks ago
Well @icanttellyou there was no errors showing up i just clicked on the icon then it says do you want to run this uknown publisher i clicked yes then nothing hapened
#41
New update is avilable.
