Okay, o was seeing hackintosh vídeos and i have a idea, make a hackintosh with MAC 10.4 on meu old XP PC, what tou think about this?
hackintosh barely works for anything unless you have specific hardware
physical mac or bust
Hmmm, like specific motherboards and processors?
I’ll need a original MAC OS 10.4 CD?
you’ll need an intel one
I have a Pentium 4 and i know where i’ll find one
That probably won’t work. You’ll might need a core 2 duo or a core duo.
I found some vídeos of ppl using on Pentium 4
ok but its probably more likely to work on a core system since macs that came with tiger had core duos/core 2 duos
after powerpc
I Will try on my Pentium 4 and i’ll say If worked
ok
Just a question can i make a bootable USB with It?
yeah but you’ll probably need to use a special iso
I’ll try with a bootable USB first
I need te right ISO bit i’m don’t find It
its easier to find one for leopard though
I’ll use JaS ISO
ok
I can’t find this damn ISO
