Trouble signing in to msn messenger
i am having trouble signing on to escargot. here is the log file:
  • Log opened: 2017-08-31T21:15:45Z
  • About this log file - MSNMsgr.txt
  • MSN Messenger 7.0.0820
  • This log file is created on your computer when the Connection Logging
  • setting is selected in the Options dialog box. You can turn off this
  • setting at any time. To turn off this setting, click the Tools menu, and then
  • click Options. In the Connection section, clear the logging check box, and
  • then click OK.
  • The only way for MSN to get this file is for you to send it to us. If you are
  • having problems connecting to the .NET Messenger service and would like to
  • report the problem to us, copy and paste this URL:
  • MSN Explorer help - Microsoft Support
  • into Internet Explorer. Fill out Sections 1 and 2 of the feedback form,
  • remembering to copy the contents of this log file into the Details box in
  • Section 2, and click ‘Submit’.
  • Caution: This file may contain personal information. Anyone with access to
  • your Windows desktop can see the contents of this file.
[21:15:48.953] Net CConnectionManager::Connect() >> Resetting wininet now
[21:15:48.968] Net CTCPNetworkLayer::Connect (2) >> connecting to m1.escargot.log1p.xyz:1863
[21:15:48.968] Net CConnectionManager::OnConnectionStateChange recieved state change for id(2) from 1 to 3
[21:15:49.015] Net CTCPNetworkLayer::ResolveHost >> resolving m1.escargot.log1p.xyz
[21:15:49.078] Net CAsyncGetAddrInfo::Run >> (0x106fe90) getaddrinfo succeeded for m1.escargot.log1p.xyz
[21:15:49.125] Net CConnectionManager::OnConnectionStateChange recieved state change for id(2) from 3 to 5
[21:15:49.125] Net CTCPNetworkLayer::ConnectToIP (2) >> connecting to 35.185.201.91:1863
[21:15:49.125] Net CTCPNetworkLayer::ConnectToIP() (2) >> success 0x0106c008, socket=1932, LastError=10035, WM(1056)
[21:15:49.203] Net CTCPNetworkLayer::OnMessage (2) >> Got WM_WSASELECT_MESSAGE(1056) from WSAAsyncSelect for socket = 1932, error = 0, event = FD_CONNECT
[21:15:49.203] Net CConnectionManager::OnConnectionStateChange recieved state change for id(2) from 5 to 8
[21:15:49.203] Net CConnectionManager::OnConnectionStateChange recieved state change for id(0) from 1 to 0
[21:15:49.203] Net CConnectionManager::OnConnectionStateChange IGNORING state change for id(0) from 1 to 0
[21:15:49.203] Net CSocksNetworkLayer::OnConnectionStateChange (0) >> changing from 1 to 1
[21:15:49.203] Net CConnectionManager::OnConnectionStateChange recieved state change for id(0) from 0 to 1
[21:15:49.218] Net CConnectionManager::OnConnectionStateChange IGNORING state change for id(0) from 0 to 1
[21:15:49.218] Net CConnectionManager::OnConnectionStateChange recieved state change for id(1) from 1 to 0
[21:15:49.218] Net CConnectionManager::OnConnectionStateChange IGNORING state change for id(1) from 1 to 0
[21:15:49.218] Net CSocksNetworkLayer::OnConnectionStateChange (1) >> changing from 1 to 1
[21:15:49.218] Net CConnectionManager::OnConnectionStateChange recieved state change for id(1) from 0 to 1
[21:15:49.218] Net CConnectionManager::OnConnectionStateChange IGNORING state change for id(1) from 0 to 1
[21:15:49.218] Net CConnectionManager::OnConnectionStateChange recieved state change for id(3) from 1 to 0
[21:15:49.218] Net CConnectionManager::OnConnectionStateChange IGNORING state change for id(3) from 1 to 0
[21:15:49.234] HmProt Sent 0x0106b6a0>VER 41 MSNP11 MSNP10 CVR0<
[21:15:49.234] HmProt Sent 0x0106b6a0>CVR 42 0x0409 winnt 5.1 i386 MSNMSGR 7.0.0820 msmsgs jarek.rosol@icloud.com<
[21:15:49.234] HmProt Sent 0x0106b6a0>USR 43 TWN I jarek.rosol@icloud.com<
[21:15:49.234] Net CTCPNetworkLayer::OnMessage (2) >> Got WM_WSASELECT_MESSAGE(1056) from WSAAsyncSelect for socket = 1932, error = 0, event = FD_WRITE
[21:15:49.234] Net CConnectionManager::OnConnectionStateChange recieved state change for id(3) from 0 to 1
[21:15:49.234] Net CConnectionManager::OnConnectionStateChange IGNORING state change for id(3) from 0 to 1
[21:15:49.328] Net CTCPNetworkLayer::OnMessage (2) >> Got WM_WSASELECT_MESSAGE(1056) from WSAAsyncSelect for socket = 1932, error = 0, event = FD_READ
[21:15:49.328] HmProt Recv 0x0106b6a0>VER 41 MSNP11<
[21:15:49.562] Net CTCPNetworkLayer::OnMessage (2) >> Got WM_WSASELECT_MESSAGE(1056) from WSAAsyncSelect for socket = 1932, error = 0, event = FD_READ
[21:15:49.562] HmProt Recv 0x0106b6a0>CVR 42 7.0.0820 7.0.0820 7.0.0820 http://url.com http://url.com<
[21:15:49.562] HmProt Recv 0x0106b6a0>USR 43 TWN S ct=1,rver=1,wp=FS_40SEC_0_COMPACT,lc=1,id=1<
[21:15:49.578] PPLogin Setting DA as https://m1.escargot.log1p.xyz/login
[21:15:49.578] PPLogin Attempting to hit Nexus
[21:15:49.578] PPLogin Downloading Nexus Data from https://m1.escargot.log1p.xyz/nexus-mock
[21:15:50.343] PPLogin Nexus Called back with
[21:15:50.343] PPLogin CMNSNet::OnPassportLoginCallback > called back with status code 12157
[21:15:50.390] Net CConnectionManager::OnConnectionStateChange recieved state change for id(2) from 8 to 0
[21:15:50.390] Net CTCPNetworkLayer::Disconnect() (2) closing socket 1932
[21:15:50.390] Net CConnectionManager::OnConnectionStateChange recieved state change for id(2) from 0 to 1
[21:15:50.468] Net CConnectionManager::OnConnectionStateChange recieved state change for id(0) from 1 to 0
[21:15:50.468] Net CConnectionManager::OnConnectionStateChange IGNORING state change for id(0) from 1 to 0
[21:15:50.468] Net CSocksNetworkLayer::OnConnectionStateChange (0) >> changing from 1 to 1
[21:15:50.468] Net CConnectionManager::OnConnectionStateChange recieved state change for id(0) from 0 to 1
[21:15:50.468] Net CConnectionManager::OnConnectionStateChange IGNORING state change for id(0) from 0 to 1
[21:15:50.468] Net CConnectionManager::OnConnectionStateChange recieved state change for id(1) from 1 to 0
[21:15:50.468] Net CConnectionManager::OnConnectionStateChange IGNORING state change for id(1) from 1 to 0
[21:15:50.468] Net CSocksNetworkLayer::OnConnectionStateChange (1) >> changing from 1 to 1
[21:15:50.468] Net CConnectionManager::OnConnectionStateChange recieved state change for id(1) from 0 to 1
[21:15:50.468] Net CConnectionManager::OnConnectionStateChange IGNORING state change for id(1) from 0 to 1
[21:15:50.468] Net CConnectionManager::OnConnectionStateChange recieved state change for id(3) from 1 to 0
[21:15:50.468] Net CConnectionManager::OnConnectionStateChange IGNORING state change for id(3) from 1 to 0
[21:15:50.515] Net CConnectionManager::OnConnectionStateChange recieved state change for id(3) from 0 to 1
[21:15:50.515] Net CConnectionManager::OnConnectionStateChange IGNORING state change for id(3) from 0 to 1
