Anyone can solve my trouble? MSN 7.5…
Lets say that your email is test@hotmail.com and your password is 1234.
To login on 7.5 you musto the following
In the email address you type test|1234@ hotmail.com
And in thes password: 1234
Ok. I’ll try make this.
When I installed my MSN 7.5 I did not install the MSN Switcher and just used the Prepatched 7.5 replace on paste. Would that problem?
You are still not putting your password in the mail field. It should be like this:
IndependentTrucks|password@live.com
Replace password with your password.
I really did not understand your explanation.
@Independent_Trucks to log in with MSN 7.5, you must put the password in the mail field at login.
For example, if your account is "hello@msn.com" with password “cool”, you must write “hello|cool@msn.com” as the mail, and anything you want (it will accept everything) in the password field, otherwise it won’t log.
Thanks! I loggin now. But why MSN automatically closing when I click on “Browser” to change the profile photo?
I solve my trouble. Thanks!
Very fortunate, I had no clue what to do about it. Can you share what you did to fix it?
