the voice call is broken on WLM ver 8.5
do you think they should fix this soon?
- yes
- no
0 voters
0 voters
Personally, I would consider that the problem should be looked into, but the people on the Escargot dev team have more important things to work on (ahem the Yahoo! frontend and OIMs ahem). Besides, the voice call problem is more of a networking issue by itself, which would take extra time to resolve.
Best thing to do in this case is to be patient and let us catch up on the important issues so that we can solve the intricacies later.
hope it come soon. i dont know whats the yahoo! froontend but anything fix it all it will be perfect
for now uses msn messenger 7.5 that his video calls are working perfectly
it seems it actually stops after somebody said “pls stop” …
they work but its no good with WLM 8.5
well at least it works
i know but if you update u cant go back unless you want version problem… i had compatibility problems when i used 7.5 & others use 8.5
