MSN on Macbook Pro
Hello all!
I was wondering if there was any supportive MSN version for a Macbook Pro.
A friend asked me to install it on his Macbook because of nostalgic reasons and after working out for about almost 2 hours I came up with no results…
I tried using Winebottler but that aint working, altough the latest version sort of works but comes without a shortcut.
Using a Virtual Machine is no option sadly enough…
Thanks already! :slight_smile:
No Mac support yet, either via Messenger:Mac or third-party clients. That should change in some way in the future.
You may want to consult another thread on this topic earlier.
as apparently you can use Wine with the older ancient versions, although that may not be the nostalgia they’re looking for :stuck_out_tongue: .
Thanks for the reply :slight_smile:
After I found out it was a hell of a ride to fix this thing I gave up the nostalgia :stuck_out_tongue:
I’ll be patient then haha :slight_smile:
