MSN Messenger 7.0 / 7.5
bonjour à tous, je suis nostalgique de MSN Messenger 7.0 / 7.5 et je voudrais savoir si il etait possible de refaire fonctionner ces anciennes versions ou les réecrire? je serai vraiment heureux de pouvoir les réutiliser, merci beaucoup de vos réponses.
Hello everyone , I am nostalgic for MSN Messenger 7.0 / 7.5 and I wonder if it was possible to re- run these older versions or rewrite them? I’ll be really happy to reuse them , thank you for your answers
msn messenger 7.0 & 7.5 are not working as of March 2015 cause the msnp that use (11.0 & 12.0 ) has been retired among with the popular MSNP 18 (windows live messenger 2009).
if you dont like the 2012 version you can use butterfly messenger:
Hi Alexis , thank you for your answer , too bad I liked this version the reuse , even modifying the program source code or can change the protocol MSNP ? This is not possible?
no cause that versions are too old to support newwer versions of protocols.
