Messenger plus works on Windows live messenger today?
I´m not sure i cannot connect to messenger at all.
ok why you cant connect to messenger?
It just doesnt work with error code i gave in other topic.
Works for me, what sort of problem are you having Tasos?
nothing jonathan thank you,im just asking because messenger plus says that '‘messenger plus does not support WLM anymore’'is that true?
It is true, Messenger was officially unsupported by everything back in 2013
However it works just fine, here is the installer. Be sure to uncheck the ‘Smartbar’ and the other optional options during the setup.
ok jonathan thank you very much!
