This confuses me to no end.
My WLM copy has suddenly stopped(???) connecting to Escargot, as if it were unpatched.
I know it isn’t unpatched, as I have chatted with other people and it has worked.
Is there any way to fix this?
Try reinstall the Messenger
I’d try accessing https://m1.escargot.log1p.xyz/NotRST.srf first.
On modern browsers, you should either get a blank page or an explicit 404 error. If that isn’t the case, then their might be something wrong with the connections to the server.
yea got a 404
Maybe there’s something wrong with the connection to the MSNP server itself.
aight what the fuck
i just signed on
it works
i have no idea what happened
Remove the m1
That makes no sense.
escargot.log1p.xyz not m1.escargot.log1p.xyz
I meant why remove the m1.
part of the URL if he can’t even access that in the first place.
http://
I can’t log in into MSN either. But I get a password-username error. Any idea? i reinstalled the program many times…
Msn? Version
MSN 7.5 and WLM 8.5…
Kappa
I found a solution
The problem was my antivirus (ESET). The solution is to enter the settings, then go to web protection and add the following exceptions:
eset reports this site as malicious and blocks access. I do not know the reason.
if your antivirus is not the same, try adding these rules in your antivirus
sorry for my bad english.
Then, save the settings and problem solved !! B)
lo mismo me pasa
lo mismo me pasa a mi
