Error 80072f7d help
hi i have this problem with messenger 7.0
i downloaded the spanish pre parched version
I have Windows XP sp2 64 bits
Unfortunately MSN Messenger 5, 6, and 7 don’t work on Windows XP with Escargot at the moment, you need either Windows Vista or an old version of Windows Messenger/MSN Messenger (4.7 or older). This is because of a feature that Windows XP is missing, specifically SNI.
okay so 4.7 and why dont have that with xp?
and how i can make messenger 4.7 work with escargot?
If you have 4.7.2009, 4.7.3000, or 4.7.3001 then it’s not possible at the moment.
If you have an older version, you have two options, you can either use the registry or your hosts file:
Option 1:
Change (or add) the registry key “HKEY_CURRENT_USER\SOFTWARE\Microsoft\MessengerService\Server” to the value “m1.escargot.log1p.xyz”
OR
Option 2:
Add “35.185.201.91 messenger.hotmail.com” to your hosts file, which is stored at “C:\Windows\System32\Drivers\etc\hosts”
(Note that if you choose option 2 it may stop working in the future, if the IP address of the Escargot server changes then you will have to change this value to match)
You do not have to do both, you can pick one or the other, they will both do the same thing.
I can sign into 5.0, 6.2 and 7.0 no problem on xp
well, posting that backfired on me. now i can’t sign in to 5.0, 6.2, or 7.0
I have the same problem that you have/had, only on a PC with Windows 98SE. With MSN 4.6 or 4.7 I can connect, while from 5.0 to 7.0 I can’t. I tried everything. Help?
bump (not a problem since you need help don’t worry)
so can I get some help with that?
5.0+ do not work on 98se due to the ciphers escargot uses being incompatible with 98, please use windows xp or newer for those versions
