Hi guys,
I´ve tried to download msn messenger at my parents place.
But I got the message: You have an older version of msn messenger installed and you have to unistall this version and then continue the installation of 7.0
I have do so and even search for something in the background that could still exist of a never messenger with no results…
If Windows Essentials is installed, uninstall it. It could be the cause of it erroring due to Windows Live Messenger’s prescence
some times the processes run in the background. try checking in taskmanager. the list of processes will be in a windows with other information. such as how much it’s using and how it effects the cpu.
They are running windows 10 btw
yes of course @Djinn it should work. did the taskmanager help or uninstalling windows live messenger help in anyway?
I haven´t visit my parents since I last wrote, but I will definitely try all the tip I can get.
